Showing results for tags 'utility trailer'.
More search options
    • Announcements
Found 2 results
  1. Over the years, utility trailers are very prone to rusting and corrosion because utility trailers are used out in the elements and then are also stored in the elements. On top of that, the powder coating that is applied by the manufacturers of the utility trailers does not last against rust and usually starts to chip off on sheets. Many of our customers have used the proven KBS Rust Prevention System to restore utility trailers preventing rust and corrosion making them last a lifetime. Below is a picture from one of our customers who restored a utility trailer over the course of a weekend. RustSeal is a superior single part, ready-to-use, rust preventive coating. RustSeal is impervious to road salts and most every chemical. RustSeal flows out to a beautiful, rock-hard, tough ceramic-like coating that is tough to chip or scratch, and will not crack or peel protecting your valuable assets like a utility trailer. BlackTop is a permanent, moisture-cured, UV stable coating primarily used for topcoating surfaces previously sealed with RustSeal or any other paint/primer application. BlackTop is a high performance protective coating specifically formulated to withstand dulling and fading caused by prolonged sunlight exposure ideal for protecing utility trailers.
  2. "Using KBS Klean, RustBlast & RustSeal and BlackTop made this trailer restoration job much easier and virtually less time consuming verses the traditional practice of grinding rust, priming and spray painting. As reflected in the pictures, KBS will exceed your expectations." -Randy P.
