Showing results for tags 'safety colors'.
Using RustSeal Safety Colors for Painting Industrial Equipment and Floor Markings Using safety colors for painting industrial equipment and floor markings is done regularly to enhance visibility, identify potential hazards, and promote workplace safety. Since the safety color paint is exposed to an industrial environment, it needs to stand up to the abuse it will receive. Safety color paints need to coat and protect equipment from corrosion, as well as stand up to the abrasion, scratches, impacts, and chemical exposure they can receive while maintaining an excellent appearance. RustSeal is formulated to do just that and is offered in a variety of safety colors for industrial applications. RustSeal Safety Colors RustSeal is an advanced technology moisture cured coating that seals the surface and prevents rust and corrosion. RustSeal bonds strongly to and seals porous surfaces like concrete. Because it is a single part coating, RustSeal is easy to apply and flows out to a beautiful, rock-hard, ceramic-like finish that is impervious to almost every chemical. RustSeal is tough to chip or scratch and will not crack or peel which makes RustSeal safety colors perfect for painting industrial equipment and floor markings. RustSeal adheres to many different materials it makes for an excellent “one-stop” safety color paint solution for coating a variety of surfaces. RustSeal can be applied with brush, roller, or spray equipment which makes RustSeal easy to apply on small and large projects minimizing downtime. RustSeal can be used to coat, seal, and protect a variety of porous and non-porous materials, including ferrous and non-ferrous metals, plastic, fiberglass, ceramic, and concrete. RustSeal is offered in a variety of colors, including the safety colors of Safety Yellow, Safety Blue, and Safety Green, for painting industrial equipment and floor markings. RustSeal Safety Colors are formulated to meet OHSA Safety Color standards. What Are Commonly Used Safety Colors For Painting Industrial Equipment And Floor Markings? Safety Red: Fire protection equipment or emergency shutdown controls. Safety Yellow: Caution, warning, or marking physical hazards. Safety Orange: Warning or caution and highlights potential hazards. Safety Blue: Non-hazardous areas, safe pathways, locations of emergency equipment, or other important information. Safety Green: Safe routes, location of emergency exits, safety information. What Indoor Industrial Equipment Are Coated With Safety Colors? RustSeal Safety Color paint can be used to identify and protect a variety of indoor industrial equipment applications. Lifting and Handling Equipment Applications include Forklifts, pallet jacks, cranes, scissor lifts, and electric tuggers. Commonly used colors include safety red and safety yellow. Safety Barriers and Rails Applications include Guardrails, crash barriers, retractable safety barriers, warehouse rack guards and handrails. Commonly used colors include safety yellow, safety orange and safety red. Pipe and Valve Marking Applications include pipes, valves, or other components that are marked as part of a color-coded system for easy identification A commonly used colors are safety blue, safety green, and safety yellow. Storage and Shelving Applications include pallet racking systems, shelving units, bulk storage racks and industrial cabinets and drawers. Commonly used colors are safety blue and safety green. Emergency Stop Buttons Applications include emergency stop buttons on manufacturing equipment. Safety red is the color for this application. What Safety Colors Are Used For Floor Markings? RustSeal Safety Colors can be used as floor marking paint and for safety line painting Fire Equipment and Danger Designate fire equipment and areas with potential danger. Safety red is the color for this application. Conveyor Systems Mark loading zones, emergency stop points, or areas where caution is required. Safety yellow is a commonly used color. Non-Hazardous Areas Designate non-hazardous areas within a facility. For example, areas with low-risk activities or areas where safety precautions are not as critical. Safety blue is a commonly used color. Informational Guidance Designate informational guidance, such as indicating the direction to emergency exits or safety equipment. Safety blue is a commonly used color. Safety and First Aid Highlight safety-related items and first aid locations. Safety green is the color used for this application Traffic and Housekeeping Designate traffic lanes, pedestrian walkways, and to define general housekeeping areas. Commonly used colors are safety yellow, white, and black RustSeal Safety Colors Identify and Protect RustSeal Safety Colors will not only create safety awareness but will protect coated equipment and floors with a beautiful, long-lasting durable finish. RustSeal will seal the coated metal from moisture and oxygen to protect against rust and corrosion. RustSeal will also seal concrete floors away from moisture and contaminants. Since RustSeal adheres to many different materials, it makes for an excellent “one-stop” safety color paint solution for a variety of surfaces. Safety Colors In Aerosol? There are times when a project calls for the convenience of an aerosol can. KBS Top Coater Aerosol comes in Safety Colors and adheres very well to equipment surfaces that have been cleaned with KBS Klean, so keep KBS Top Coater Aerosol in mind as an option when the project requires the convenience of an aerosol can. Questions? Have questions about using RustSeal Safety Colors for painting industrial equipment and floor markings? If so, please let us know. Please Contact Us HERE.
- safety colors
- industrial paint
(and 2 more)
Tagged with:
