Showing results for tags 'leaking tank'.
  1. “I could not order a tank and the nearest is two states away-sooo-blacksmith-it. Your KBS Patch was simple (thanks) and easy and it works! Another reason to by American. Used KBS Klean then elbow grease then "a little blast" then KBS Patch. 15 minutes in sunlight and put it back on. No leak! Great! Luv. It. Will buy some more for the farm. Thanks!” -Rick H. from IA Check out KBS Patch. KBS Patch is an easy-to-use, UV/sunlight activated repair patch. The fiberglass-reinforced polyester patch creates long-lasting repairs. Perfect for making watertight, durable repairs on engine parts, decking, fenders, gas cans, drain pipes, water tanks, PVC pipes, plastics, Plexiglas, fiberglass, metal, wood, concrete and more.
