Showing results for tags 'fishing lure'.
“KBS Coatings sets the standard on durable finishes. I use DiamondFinish Clear 1K Aerosol to protect the paint on my custom baits and it wears like iron. If you want a product made to stand up a in a tough marine environment, this is it. Tough as nails, great gloss and made in the USA!” -Speedbaits in Jacksonville, FL DiamondFinish Clear 1K Aerosol is a tough Clear Coat that can be conveniently applied Direct To Ferrous Metals and Aluminum or over other coatings. DiamondFinish Clear 1K Aerosol is a water clear aerosol clear coat that utilizes a professional grade acrylic resin system for supreme clarity and adhesion. DiamondFinish Clear 1K Aerosol does not yellow, crack or peel. DiamondFinish Clear 1K Aerosol Link -> https://www.kbs-coatings.com/diamondfinish-clear-aerosol Please contact us with any questions today.
- clear coat
- lure clear coat
(and 3 more)
Tagged with:
DiamondFinish Clear Is The Ultimate Clear Coat for Fishing Lure Makers DiamondFinish Clear is an ultra-long lasting, moisture cured clear coat designed to add body, depth, and a rich gloss to your fishing lures. DiamondFinish Clear is extremely durable because of its high solids content but at the same time DiamondFinish Clear always remains highly flexible. DiamondFinish Clear is guaranteed to never yellow or crack and can be used over metal, plastic and wood as a crystal clear seal coat. DiamondFinish Clear can be applied by dipping, by brush, and spray gun. DiamondFinish Clear is also ideal for suspending glitter in your finishes. Get some DiamondFinish Clear Coat for your fishing lures today and take your artwork to the next level!
- fishing lure clear coat
- fishing lure
(and 1 more)
Tagged with:
DiamondFinish Clear is the Preferred Clear Coat of Fishing Lure Makers! 👍Easy Application 👍Insane Durability 👍Water Clear Shine 👍High Solids = More Coverage Per Coat 👍Ideal For Immersion in Water
- clear coat
- fishing lure
(and 2 more)
Tagged with:
- fishing lure
- clear coat
(and 1 more)
Tagged with:
