Showing results for tags 'diamondfinish clear'.
DiamondFinish Clear is the Preferred Clear Coat of Fishing Lure Makers! 👍Easy Application 👍Insane Durability 👍Water Clear Shine 👍High Solids = More Coverage Per Coat 👍Ideal For Immersion in Water
- diamondfinish clear
- crankbaits
(and 2 more)
Tagged with:
“Used DiamondFinish Clear to coat my new aluminum flagpole. Product went on like a dream. Flagpole looks great and my DIY coating saved me a couple hundred dollars for a "factory finish”. The product appears to be very tough, withstanding the constant "clanking" of the halyard clips. Now I'm looking for other applications!” -Kevin from Portland, TN With a little imagination, DiamondFinish Clear has an unlimited number of applications for clear coating over steel surface as well as non-ferrous surfaces like polished aluminum. DiamondFinish Clear is a crazy t
- uv stable clear coat
- durable
- (and 3 more)
At KBS Coatings, we love Rat Rods just as much a Classic Car restored to original OEM perfection. Rat Rods are really fun and allow for creativity and artistry. But as with any vehicle, you need something to protect the vehicle and DiamondFinish Clear is an ideal clear coat to keep a patina look on your Rat Rod. Check out the 1974 Challenger and the beautiful stainless steel patina look.
- challenger
- clear coat
(and 3 more)
Tagged with:
Because DiamondFinish Clear is a moisture cured urethane, which means it is cured and strengthened by moisture, it is absolutely ideal for all marine type applications. DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal or over other coatings for a hard durable and flexible finish. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- moisture cured urethane
(and 2 more)
Tagged with:
- crank baits
(and 2 more)
Tagged with:
DiamondFinish Clear was used to restore the front on my Fifth Wheel. DiamondFinish Clear is a crazy tough Clear Coat that can be applied to faded fiberglass to bring it back to life. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- restored fiberglass
(and 1 more)
Tagged with:
“Flame painted copper is done with a torch. NO paint. We use the DiamondFinish Clear to seal the copper and keep the colors permanent.” -Randy A from Scottsdale, AZ DiamondFinish Clear is a crazy tough Clear Coat that can be applied Direct To Metal (ferrous and non-ferrous) or over other coatings. DiamondFinish Clear is a water clear high gloss clear coat that remains permanently flexible and is able to perform in the toughest environments without yellowing, cracking or peeling.
- torched copper
(and 1 more)
Tagged with:
“This stuff is just amazing. Honestly. I am preparing my racecar for the upcoming Time Attack season and wanted to tidy things up for those impromptu photo shoots at the track. All I can say is well done. Stuff is tough and just looks killer. More folks should know about this stuff.” - Chance C. https://www.kbs-coatings.com/DiamondFinish-Clear-Aerosol.html
“I purchased the diamond clear to use on my wheels on a 77 El Camino. The wheels were chemically stripped and the outer wheel was sanded and polished to an almost mirror shine (as good as my patience would allow), the center of the wheels were base coat and clear coat with standard two stage paint system. I reduced the diamond clear the full 30% for spraying. The clear was wet sanded after 2 days with 2000 grit and then compounded with a wool disc at 1500 rpm. In the end the wheels turned out very good!” -Tim G DiamondFinish Clear
- clear coats
- wheel paint
(and 2 more)
Tagged with:
“This is my original artwork over a red Lyon - Washburn Guitar. After a few coats of inferior products I needed that glass finish and decided to go with the KBS DIAMONDFINISH CLEAR and after only two coats from my HVLP gun the result was perfect and EXACTLY what I was looking for. Thanks so much for the product and letting me share this work of love with you. I will be using this product to finish all my rebuilds.” - Ron S. https://www.kbs-coatings.com/DiamondFinish-Clear.html
- clear coat
(and 1 more)
Tagged with:
DiamondFinish Clear: https://www.kbs-coatings.com/DiamondFinish-Clear.html
- fishing lure
- clear coat
(and 1 more)
Tagged with:
“Here are just a few pictures of what I do, new metal art. I am looking forward to much better sales this year due to using the KBS Diamond finish. WOW!!!, what a difference. Everything has a completely different dimension than before. The different colors and even the plain raw metal stands out. I say we have the "WOW" factor now. Some of our customers who have already seen the difference are amazed. We are really excited that we discovered KBS Coatings!” -iMetalist from Burleson,TX https://www.kbs-coatings.com/Clear-Coats.html
- clear coat
(and 1 more)
Tagged with:
“This was a 4 X 8 foot plywood sign (double-sided) that I originally did about 8 years ago, for a friend's restaurant. It was very faded and weathered; but the basic plywood was still in good shape. So we sanded it well, primed and re-lettered it.(hand painted). Then put the KBS Diamond Clear on it. Looks great!! It sits out in a parking lot, with one side in the sun for most of the day ... I'm very satisfied with the product, so far.” -Dale F. DiamondFinish Clear
- plywood sign
(and 1 more)
Tagged with:
68 C-10 Engine
KBS Coatings posted a topic in Customer Photos, Videos, Feedback, and Success Stories
“Before & After pics of my LT1/4L60E for my '68 C-10 project. All coatings are Motor Coater. Block is Velvet Black, the rest are Gloss Black, and Aluminum that has been Diamond Clear-coated. Diamond Clear on raw polished aluminum and steel parts as well. Motor Coater and Diamond Clear are my "go to" coatings for the things I want to have a nice finish on. Awesome stuff!” -Chad M. Motor Coater | DiamondFinish Clear-
- 68 c-10
- motor coater
(and 2 more)
Tagged with:
“1976 Honda trail 70 I restored using all KBS products. KBS Strip, RustBlast, Black & Crazy Plum MAXX paint & DiamondFinish Clear ... All products worked just like they said they would. MAXX & Clear sprayed perfect with high gloss an no runs ... As a matter of fact I couldn't make it run!!! All dried supper hard! Then used KBS UnderCoat inside frame. On motor cases I used the silver Motor Coater & topped it with the DiamondFinish Clear. I tell all my friends about how good KBS Products are!” -Robert T.
- motor coater
(and 2 more)
Tagged with:
“DiamondFinish Clear came out really great after letting the base coat (Pettit EasyPoxy polyurethane/silicone) cure for a week and after only one coat of DiamonFinish brush-on clear, some wet sanding with 1000 and 2000 grit and compound in some areas and to fix a few sags due to shape of the object. ...I'm very happy with the result.” -Marinus Please check out DiamondFinish Clear.
- clear coat
(and 1 more)
Tagged with:
“A few years back I was searching for a product that I could brush on and level itself to a sprayed finish appearance. DiamondFinish Clear was it! I use this product to seal and finish out door public art sculptures. These photos are of the most recent project I'm working on which made the news during a press conference. Thank you for the quality professional Finish from KBS !! I'm also letting more people know how great this product is. I have been spraying and brushing finishes for twenty plus years and have never used a better product with a brush than KBS DiamondFinish Clear. Thank you!” -
“This clear-coat adds luster and value to our fishing lures. Our customers really appreciate the quality.” -RSR Lures DiamondFinish Clear
- fishing lures
- clear coat
(and 1 more)
Tagged with:
Can I thin DiamondFinish Clear to spray it?
I'm very happy with the results, using Diamond Clear on a couple of custom signs. I have always tried to do top quality work, but clear coats have failed many times in the past. Yours has worked great so far. The only concern I have is with storage of the unused portion of the quart. Can this be done? My first quart hardened solid in a couple months, despite the lid being on tightly. I had used about half of it. I don't use a lot, and not too often. But I will definitely consider becoming a long-term customer. Most other solvent-based enamels, I can 'drizzle' a thin layer of thinner over
Hi, does DiamondFinish Clear dry glossy like a 2k paint, or would I need to cut and buff it like an acrylic clear? Also, will it fade over time like regular 1k acrylics?
- 1 reply
- cut and buff
- clear coat
(and 1 more)
Tagged with:
Can I use DiamondFinish Clear directly on wood without a sealer, and is the results a high gloss finish.
which is the most durable and chemical resistant, Diamond clear or Maxx clear ?
- 3 replies
- clear coat
(and 1 more)
Tagged with:
