“I am restoring a55 2nd series Chevy pick up. First I mechanically removed the heavy scale with a wire wheel. Then washed everything with KBS Klean, at a 10 to 1 mix. It worked great and cleaned all oil and grease residue,I rinsed and let it dry. Then came the RustBlast, I sprayed it on, kept the parts wet and the rust disappeared, when I was happy with the result, I rinsed and let dry. Now all part had a zinc phosphate coating. Then I applied 2 thin coats of rust seal. This stuff is tuff and dries hard and encapsulates the steel. I don't see how it could ever rust again. Great products yield
